WTD 3.5 V8
Charlie_Zetec - 22/5/11 at 08:24 PM
I'm after a Rover 3.5L V8 lump on behalf of a fiend of mine.
Ideally based in the Essex area (Chelmsford/Harlow, but happy to look further afield) and cheap cheap like the bird. Not fussed if it needs taking apart and inspecting, replacing gaskets etc., but he (or more likely I) don't fancy a full rebuild dwn to nuts, bolts, rings etc..
Can collect, or arrange courier if a bit far out, but open to suggestions.
Please U2U with any information, thanks!
marcjagman - 22/5/11 at 09:02 PM
Rover 3.5 V8 engine | eBay UK
coozer - 22/5/11 at 09:24 PM
I have one here..£50
Simon - 22/5/11 at 10:46 PM
I have my old 3.5 V8 (now got 3.9 in car) sitting on my garage floor.
I don't want anything for it, but you may need to source a distributor (might have one) as I cut it down so it'd only drive oil pump, and I'll remove all the injection stuff from it, but you can have the orig carbs/maniifolds.
I'm in Paddock Wood.
Simon
mangogrooveworkshop - 23/5/11 at 11:39 AM
got a picture of it ?
coozer - 23/5/11 at 11:59 AM
Indeed...
Charlie_Zetec - 23/5/11 at 12:34 PM
Simon
Cheers Simon, sounds good to me!
If it's alright with you, I'll check tonight and get back to you tomorrow - but you're the nearest by a way! We can sort out collection at a later date, sort of depends if I'm needed to assist with moving said item.
Once again, big thanks to LCB for coming to the rescue!
scudderfish - 23/5/11 at 12:48 PM
£50 to take it away, you'll have to cough up more than that!
