Left hand M4 bolt
greggors84 - 22/6/12 at 06:16 PM
Looking for some M4 bolts with a left handed thread.
Found a drill chuck bolt on amazon but its about £15 including delivery.
There are some left hand rod ends on ebay too but are around £5 each and not sure if I butcher them for my purpose.
Anyone know of a cheaper source.
nick205 - 22/6/12 at 07:56 PM
Always taught to look from another angle....
What do you need it for?
Could the mating part be changed?
Could someone with a lathe make you one?
greggors84 - 22/6/12 at 08:01 PM
Its for removing a bolt from a recessed hole.
Unfortunately the part cannot be changed, it needs to be left handed for it to work and cannot be bigger than M4.
Someone could make the part on a lathe but Im sure it would be very fiddly to do and thought it would be more cost and time efficient to try and locate a source as it might not be a one off. If I can't find any for a reasonable price then I may be asking kindly for anyone with thread cutting tools to make me a few.
nick205 - 23/6/12 at 10:10 PM
Could you use a stud remover?
nilocp - 26/6/12 at 09:49 PM
You will need a LH tap as well!! MOre expense!
will642 - 26/6/12 at 10:13 PM
left hand taps on ebay item no
350343874352
slingshot2000 - 26/6/12 at 11:31 PM
It would need to be one suitable for removing a left hand threaded stud, wouldn't it ?
Regards
Jon
