Looking for a split 530 sprocket any make to fit Quaife ATB QDF7ZR diff.
I believe that radical prosport use the same diff, so an unused or very good condition radical sprocket would be perfect.
Tooth wise 47 is needed but may take any if the price is right.
Thanks in advance.
I get mine from Talon Engineering, hardened alloy, either plain or with lightening holes, they'll cut them in half for you but to be honest it's a 2 minute job with the hacksaw. They know the correct PCD etc. for a QDF7.
Cheers will check them out.
Don't think I'll risk lightening holes being split though.
If there is a big difference in price I may resort to cutting one on a bandsaw.
The lightening holes don't affect he strength. From memory it's about £2 extra supplied split
That's not too bad, you can't grumble at £2 for peace of mind.
