Picking up an ST170 engine to try in the Quantum shortly.
Just wondered if anyone has a suitable flywheel sat about doing nowt?
Popular options seem to be the CVH EFi or 1.8 Zetec ones.
A 220mm clutch in good order would be a bonus
PS I'm planning to use the cars current gearbox that's bolted to a 1.4 CVH currently.
I may have a new or nearly new 220mm clutch, I’ll dig around the garage after work.
I am guessing you are using the Bc or Ib5 gearbox ? These lighter duty boxes have a smaller first motion shaft so you can't use the clutch used
by others on a t9. With the power of the st I would do some home work on the Escort Rs turbo clutches. But you may get away with a standard clutch set
up from a 1.6 / 1.8 zetec escort but not the 130ps spec that had the 2.0 fly and clutch to go with the mtx75.
The efi cvh flywheel is very rare and came in fwd and rwd sizes. I would stick to a Zetec E 1.8. You're less likey to pick up the wrong one.
Originally posted by big_wasa
I am guessing you are using the Bc or Ib5 gearbox ? These lighter duty boxes have a smaller first motion shaft so you can't use the clutch used by others on a t9. With the power of the st I would do some home work on the Escort Rs turbo clutches. But you may get away with a standard clutch set up from a 1.6 / 1.8 zetec escort but not the 130ps spec that had the 2.0 fly and clutch to go with the mtx75.
This the one?
eBay Item
That the going rate for one of these?
Casesensetive on the MEV forum has done some great work on documenting all required wiring to get the st170 running on the standard ecu. I'm
currently using this to get my engine wired up.
http://mevowners.proboards.com/thread/9185/loom
Is this what you're after?
https://photos.app.goo.gl/RJjFYLX32PTDqejy5
Wouldn't add to photo archive for some reason, sorry about the google link.
Originally posted by FamilyGuy
Casesensetive on the MEV forum has done some great work on documenting all required wiring to get the st170 running on the standard ecu. I'm currently using this to get my engine wired up.
Originally posted by Nickp
This the one?
eBay Item
I have just upgraded my clutch so I have a 1.8 zetec flywheel and clutch kit for sale
It was fitted to a type9
[Edited on 20/6/18 by chris]
This the one?
eBay Item
Looks correct. Easy way to tell is a big chamfer on the top outside edge but it’s a bit hard to see in that photo.
This is the 2.0
