Hi guys,
Just wondering if this is ok or if all lights must be controlled by on/off buttons?
Side lights automatically on when ignition is switched on,
Dipped then automatically on when engine is started,
And a switch to turn on full beam.
Any help would be great,
Dave
What was your donor loom from a Volvo?
Ha, no just the original r1 loom.
I like the way it's working just thought I'd check there's no IVA reg stating I've got to be able to turn the lights on and off?
Don't see a problem with that of course you will have main beam warning tell tales etc
My Front white leds, are wired up to the plus side of the coil, so as long as the engine is running, my leds are on
I was just to laxy at the time to add another wire from the fuse box, but may do over the winter
May be wrong, but dont the side lights need to be able to be switched on without the engine running, "ie" when the vehicle is parked on the road at night. Cheers Ray
i think that's right you must have the ability of having side lights on at night as "parking" lights, but other wise i think its ok for lights to come on with the ignition....there must be a tell tale for the sides/dips as well (dash illumination lights do for this.)
Parking lights are only Optional for the IVA, for vehicles under 6m. Your sidelights must come on with one switch, which can be your ignition switch. All lights must have telltale indicators on the dash.
No reason IVA should have issue IMO, but I think i would want the ability to control them though. A couple of scanarios - heavy fog - headlights can make it a lot worse. Leaving the car on a dark road, I would want to leave my sides on (even if it was for 30secs while I posted a letter, got some cash out, etc etc)
I have a 56 Fiat Doblo that extinguishes all the lights when I turn the key off, and, I cant find anything that looks like a parking light..
Originally posted by MK chippy
Hi guys,
Dave
Our Renault does that, but it still has a headlight switch tho, so you can turn off the headlights, then back on again and the sidelights will stay on
even with the ign off.
turn the key one more click anticlockwise and it puts the sidelights on and remove key.....yet another brilliant piece of Italian engineering
[Edited on 18/11/12 by theconrodkid]
