Hazard warning / indicator switch wiring problem
alland3851 - 24/8/15 at 04:10 PM
Hi I am wiring up hazard and indicator using durite switches. I have managed to get the hazards to work properly but the normal indicators run at twice the rate they should be. Any suggestions on what I have wired up wrong or is there something else I am missing ?
Thanks for any help
Chris_Xtreme - 25/8/15 at 07:45 AM
do you have normal bulbs all round or some LEDs?
a normal flasher relay needs enough load to make it go at the right speed. if not enough - ie a bulb fails or led in place, then it goes faster.
alland3851 - 25/8/15 at 05:10 PM
Thanks for the info. I checked the front indicators and turns out that they were from a M/Cycle. Changes indicators and working ok now
Your help much appreciated.
Chris_Xtreme - 25/8/15 at 06:40 PM
nice one, glad it was something simple
