My wife wants a Toyota Yaris and I notice that the hybrid version is not much more than the petrol (an extra £2100 on the new list price).
Now I've worked out that £2100 buys you 400 gallons of petrol. If the hybrid system saves you 10MPG then 4000 miles pays back the extra. Even
if it's only 2.5MPG extra, you've still paid back the extra cost in a year, so it's a goer financially. And as her job takes her
across the city a few times a day, she'll be doing ideal journey types for a hybrid.
So here's the big question. Should I recommend it to her? Is it likely to cause problems down the line or are hybrids well sorted by now?
Hybrid may be in a lower road tax bracket as well?
dont think youve worked that out right... how can 4000 miles cost £2100 in fuel
The biggest problem with hybrids (for me) is that the batteries have a finite life - how much will a new battery pack cost, in a few years time?
Still can't see it, unless she does a phenomenal mileage. Assuming 10,000 miles per year, and £1.15 per litre:
10,000 miles @50mpg = 200gal = £1040
10,000 miles @60mpg = 167gal = £871
10,000 miles @70mpg = 143gal = £746
10,000 miles @80mpg = 125gal = £650
So from 60mpg to 80mpg you save £220 which means it would take nearly 10 years to save £2100.
[Edited on 15/6/15 by geoff shep]
How are you buying the car and how long will you keep it? if you plan to have the car just a few years it will be under warrantee the whole time, in
which case I'd have no fears about the hybrid systems as they should be covered.
As to the cost, have a look around and see what your dealer is offering as you might find the actual difference in cost is a lot more, or a lot less
than £2k because of what they've got in stock or what they want to shift. On a similar note have a look at predicted depreciation differences
between the two. Its not an exact science but they may depreciate at different rates making one of the cars a much better prospect (I would like to
clarify though I've never take depreciation into account when buying a car but I've also never taken fuel economy into account either). If
you go for PCP it will make a big difference.
The final suggestion, get her to have a go in both. If you're buying new any dealer worth his salt should have no issue with this, especially if
he can get you in the pricier car.
Originally posted by morcus
How are you buying the car and how long will you keep it? if you plan to have the car just a few years it will be under warrantee the whole time, in which case I'd have no fears about the hybrid systems as they should be covered.
Originally posted by morcusThe final suggestion, get her to have a go in both. If you're buying new any dealer worth his salt should have no issue with this, especially if he can get you in the pricier car.
I'm sure they proved the hybrid is nowhere near as good as it is claimed. The Polo Bluemotion (as an example) gives better mileage in the real
world.
I take it you definitely want new? Going for a 2 or 3 year old petrol Yaris would give you the same couple of K saving (if not more).
Originally posted by Slimy38
I'm sure they proved the hybrid is nowhere near as good as it is claimed. The Polo Bluemotion (as an example) gives better mileage in the real world.
quote:I'd take a year old car if it came at a good price. We did last time. But as she uses it for work several times a day, it has to be 100% reliable. I don't want the bother of changing it every couple of years. A new(ish) one at a good discount works out reasonably well for 4 or 5 years.
Originally posted by Slimy38I take it you definitely want new? Going for a 2 or 3 year old petrol Yaris would give you the same couple of K saving (if not more).
The problem with all batteries is the life expectancy is unpredictable, but istr Toyota give a very long warranty transferable on the battery pack.
One major snag at least with the last gen of the Prius was that the heater was infective in stop start driving.
The Atkinson cycle is not really a thermodynamic cycle at all it is just an increase in the offset of the crank centreline from that of the cylinder
bores and a longer duration on the inlet cam. If it produced worthwhile results all car manufacturers would have done it years ago.
Unless they ban diesels from city centres or you do a lot of city driving I'd get any diesel
I have a plug in hybrid which is fantastic in towns and cities where it just uses electric
Country roads c 40to50 mpg
Motorways less than 30 once you've used all the electricary
Wife's c class merc does 61 on a run ????
It's party piece is over 80mph the motors and the 2 litre petrol engine join in and it flys
[Edited on 28/6/15 by Lightning]
The Atkinson cycle is not really a thermodynamic cycle at all it is just an increase in the offset of the crank centreline from that of the cylinder bores and a longer duration on the inlet cam. If it produced worthwhile results all car manufacturers would have done it years ago.
OK, now I've done the sums properly, it would take her 3 years to pay back the difference if the official MPG figures can be believed or 4.5 years if you assume the hybrid only makes half as much difference as they say it does. It's still about fair enough.
What's I'm really after is about the batteries and hybrid system. Are they generally reliable? How long will the batteries last?
We did back to back test drives of the shortlist yesterday. The corsa failed the boot test. They've panneled in the wheel arches so you
can't fit a piano keyboard in the boot (SWMBO is a music teacher). The Yaris was good was good. The ride is a bit firm and the interior space a
little bit tight but we were happy enough to get one. but then we drove the Peugeot 208. I asked the Toyota salesman about real worked MPG saying
that the other cars we were looking at all offered 50+ urban MPG. He changed the subject to the 5 year warranty.
The facelifted 208 is much bigger inside, drives more nicely and has a a proper gearbox. The salesman recognised me from last time and offered me an
11.5% discount without me having to ask. We had an intersting test drive. Some girl on a mobile walked into the road from behind a parked transit
without looking. We stopped very quickly. She didn't even flinch.
I'd be happy to have the Yaris hybrid, but the 208 is a better car and for a lot less cash. With the Pug's official urban fuel consumption
of 51 MPG, I suspect there's not that big a fuel saving to be had from the Hybrid, so we'll be getting the normal car.
[Edited on 15-7-2015 by smart51]
You could buy the hybrid... but then you've got to start splashing out on Quorn sausages, hemp clothing, wooden bracelets and the like.
But have you factored depreciation? That can be a killer on some cars, peugeot I suspect may be heavy, but offset by initial costs. Toyota stuff tends
to be quite sought after, and I expect a hybrid to hold its value rather better, especially if changing after 3-5 years.
We did back to back test drives of the shortlist yesterday. The corsa failed the boot test. They've panneled in the wheel arches so you can't fit a piano keyboard in the boot (SWMBO is a music teacher). The Yaris was good was good. The ride is a bit firm and the interior space a little bit tight but we were happy enough to get one. but then we drove the Peugeot 208. I asked the Toyota salesman about real worked MPG saying that the other cars we were looking at all offered 50+ urban MPG. He changed the subject to the 5 year warranty.
The facelifted 208 is much bigger inside, drives more nicely and has a a proper gearbox. The salesman recognised me from last time and offered me an 11.5% discount without me having to ask. We had an intersting test drive. Some girl on a mobile walked into the road from behind a parked transit without looking. We stopped very quickly. She didn't even flinch.
I'd be happy to have the Yaris hybrid, but the 208 is a better car and for a lot less cash. With the Pug's official urban fuel consumption of 51 MPG, I suspect there's not that big a fuel saving to be had from the Hybrid, so we'll be getting the normal car.
hybrid
