Finally I have go the dampers changed on my sister 206 . It was a bit of a job to fit the lower ball joints but brute force and ignorance won the
day. Thanks for all the advise guys. I am now having trouble fitting the trackrod end back to the hub.
When I try to tighten the nut the ball joint just spins, I have had a look at the trackrod end and I cant see anywhere to attach a spanner to it to
stop it from spinning. Hopefully someone has done this and will know what to do so I can finely be done with this car. Any advise is appreciated.
Regards
Rhod
get a lever behind the ball joint and push it into the taper really hard and hold it there while you tighten it
(its only the fit/friction in taper that stops it turning)
once it starts to tighten it will grip without the lever
[Edited on 23/1/09 by mcerd1]
Failing the above I have had success with a gcramp to nip it into the taper and if you just offset it a little you can leave room to get the nut
on.
Cheers for the reply's I've managed to do it by levering it up . All I need to do now it fill up the gearbox with oil, but that's not
going to happen for a while. I'm now going to have to go out and buy a drain plug removal thing/kit because the Peugeot drain plugs are square
and I don't have anything that will fit . I HATE French cars!!!!!!! Oh well of to Halfords in a bit.
Regards
Rhod
I used to use have an old 'T' bar from some random socket set (but it was a weird size for a socket set)
now I've got a better one I made by grinding down a 'universal' sump plug spaner till it fitted
You don't need to buy a kit, just get the one you need. 8mm square IIRC
