The local scrotes have tried to steal my trike by forcing the ignition. With damage to the chassis where the steering column bolts on, and damage to
the one off fibreglass housing I made, I reckon its not worth fixing. So I'm idly considering a new project. I was thinking of taking a 90s
hatch and cutting off most of the body work, after welding in a tubular steel chassis. Lower the suspension and the front seats. Ditch the rears.
Some GRP bodywork and I'd have an open top fun car.
So what would make the best donor? Something that handles well and is light weight. What would you choose?
Cinqecento sporting.
Its light enough not to need too much body removing.
[Edited on 28/9/15 by balidey]
mk5 fiesta zetec s with a 1.7 puma conversion. . . .or 2ltr zetec
mx5 ?
or given your username
smart car...
I have a Puma that needs to live again!
Hardly the 90's but I know that a VVC K series engined Metro is rather brisk!
Originally posted by smart51
I was thinking of taking a 90s hatch and cutting off most of the body work, after welding in a tubular steel chassis. Lower the suspension and the front seats. Ditch the rears. Some GRP bodywork and I'd have an open top fun car.
The answer is:
A Corvette C4
As they are a bit thin on the ground in the UK, how about something along the same lines (V8, RWD, cheap) e.g. an old Lexus? By the time you've
removed most of the interior and a sizeable part of the bodywork the weight should be pretty reasonable.
Banham???????
205 base 3 door with 106 gti/306 gti6/xsara vts running gear.
Cheap, 90s and can handle fantastically.
Get a cti and you just need to remove the windscreen.
Cut down small Fiats always look super fun, maybe an cinq or an Uno.
Even his Holiness is a fan.
