Hi all,
I'm looking to get more power to the garage and was wondering about the different prices of double sockets.
I have my eye on 5 of these
https://www.tlc-direct.co.uk/Products/CM3356.html
But are they cheap for a reason, MK metal clad are £13 a pop, its quite a jump.
The feed to the garage is plenty man enough for 5 doubles, as its coming out the 3phase box in the bakery.
Just looking for a fair priced metal clad socket recommendation.
Do they have to be metal-clad? You're paying a premium for that decorative feature.
Ordinary twin sockets from reputable makers are as cheap as chips.
I've had stuff from TLC, it's been good in the past. Say British made with 25 year guarantee. Not sure about the British made part ,
but 25 years sounds like they're built to last.
Screwfix £4.99 13A 2-Gang SP Switched Metal Clad Socket with White Inserts (69127)
I would use Double Pole (DP) switched sockets. Many are SP.
DP disconnects live and neutral, which is preferable. But not essential.
If you chose to use plastic surface boxes, avoid the cheap crappy ones. They crack/break just for a laugh, or the brass screw inserts pull out. You
can (or could) get PVC ones which are much more durable.
Might be a good idea to fit one or two with USB charging points built in?
Originally posted by nick205
Metal clad ones seem OTT for a garage really.
I dont know how any one can break a patrice box and socket plate, as i have never done so! nor seen it, and i worked for an electrician
My garage has normal white Mk sockets, and ive never had a problem with any of them, nor anywhere else in the house, and in the 34 years we have been
in this house/garage ive rebuilt several Minis, a couple of motorbikes, and made a Locost from scratch, and never had an issue!
As for the Usb plates, we have a couple in the house, and in the garage, and ive never paid more than £9 each for them
Unless your garage is going to be a full on industrial workshop with 3 phase machinery, etc, metal boxs imho are a total waste of money
steve
I dislike the built in usb sockets, since
a) typically they take a constant 2W load - even when not in use *
b) only dumb slow charging
c) have to replace the whole socket when the usb bit fails
* they tend to use a capacitive dropper psu, since they are small and cheep.
plugin chargers tend to use switch mode psu, which are more efficient, and allow for higher power (fast charging)
I say, just use a plugin charger
Built-in chargers have the great advantage that they do not get taken off by your children to other rooms and leave you searching for them after they have gone to sleep!
I got a bundle of metal MK sockets from a car boot. Think I paid £2 for 10. All have been found to be in perfect working order. I think many were
hardly used. The only issue is that they are Gold
quote:nope, no arguments, just good honest discussion
Originally posted by pigeondavebut I don't want to start an argument amongst you all
The garage is at the (family) bakery and I'm the only one that goes in there really, so its not a massive issue.
Thanks all for chatting this one through, I'm going to go with the linked ones, they're reasonably priced for metal and I fancied metal.
I would ask should I get 3phase piped down there as I have two spare slots on the board in the bakery, but I don't want to start an argument amongst you all![]()
Thanks again everyone
You are local to me, I was at Denmays yesterday.....
Be careful about linking to the bakery. I suspect commercial electrical testing is quite fussy?
But 3 phase would be a lovely idea, plenty of quality kit out there that us single phase people can't buy, so tends to be very cheap. Lifts/compressors/welders even lathes/milling machines.
There seems to be a better alternative now according to this video (it's in the right place)
https://www.youtube.com/watch?v=HIsTK42o8g0&t=297s
Seems these new ones will do fast charging
https://www.hamilton-litestat.com/decorative-wiring-accessories/eurofix/usb-power-sockets-modules/
Wonder if they still have a parasitic draw?
Back to the sockets, you would have to be very silly not to use metal-clad. I'm an electrical engineer and I've seen umpteen cracked plastic
sockets but to put it in perspective, never a directly connected fatality, although I've heard about them
Toolstation metal-clad are good I fitted them in my garage and in the kids garage as well.
Remember to make sure you have a metal-clad fuse board ( mandatory due to fire regs) with a min of 1 RCD protecting the sockets. New regs require RCD
on lighting circuits as well.
When wiring to the sockets the wiring will have to be mechanically protected and for the sake of a few quid whats not to like about fitting plastic
conduit where liable to damage?
Check the loop impedance, if its poor all the protection in the world is worse than useless, worse cos you think its safe when its not.
After all that doom and gloom if you can make a kit car this should easily be within your capabilities if you do your research.
Happy Sparks
Cheers!
While conduit is good practice, there is no requirement for conduit or any mechanical protection for surface mounted T&E, unless the regulations
have changed. Indeed, although RCDs are required for sockets or for cables buried less than 50mm into walls, I don't think they are needed for
surface mounted cables - probably because there is no danger of someone accidentally knocking a nail into one or drilling through it.
In my own case, I have used both conduit and RCBO though and I do think it would be daft not to.
While I would not install without protection anyway, there is a big difference between a commercial workshop (with health and safety requirements) and
a home workshop/garage. Practically it makes sense to protect, but there is no requirement to.
Home and workplace fall under different requirements. All my garage and shed sockets and lighting and sockets are both RCBO protected and protected by
conduit (my choice), but the garage lighting is standard fluorescent tubes, without protective covers - which would not be accepted at such a low
level in a commercial workshop.
