Hi,
The MT75 i have looks like it might be leaking oil, so I'm thinking of swapping it for a Type9 with a BGH gear kit over the winter.
Is the Type9 a direct swap to replace a MT75, I'm mainly concerned about having to relocate the Engine Mounts, and would like to avoid that if
possible. I'll probably be using the Burtons Ali Bell Housing.
I'm trying to get an idea of the knock-on effects would be of the swap, to gauge if its worth doing or not.
you'll need a new propshaft
Rally Design for the ally bellhousing, half the price, you may also need an RS2000 release arm and a cct113 release bearing.
Gearbox mount will be in a different position
Prop shaft may need to bo shorter with a different fitting arrangement.
If you use an RS2000 bellhousing you either need an RS2000 ally sump or make up a steel plate to cover the unused starter motor hole which also mounts
the clutch cable
Its a lot of work and money when another mt75 is so cheap.
Is it the ratios your not keen on ?
Thanks for the replies, its given me something to think about.
Hi all
Just been having a quick look at this thread anyone interested in a Type 9 with different ratio set take a look at my site
http://www.firstmotion.co.uk/ as we specialise in standard recons and ratio changes for both boxes hope this is of help to some of you
Regards
Paul
