1800 sierra
hootsno1 - 24/1/11 at 07:32 PM
Hi all
Can anyone tell me if the gearbox and diff in the 1800 sierra are the same as the 2.0lt
many thanks
big_wasa - 24/1/11 at 07:42 PM
Depends on engine. If the 2.0 is a dohc then no
whitestu - 24/1/11 at 08:35 PM
Most 1.8 CVH Sierras have Type 9 & 3.62 diff, but they do vary from car to car.
Stu
handyandy - 24/1/11 at 08:41 PM
My 1.8CVH Sierra donor came with a Type 9 box & a 3.92 diff, it was an estate version so not sure if that had anything to do with the diff ratio .
cheers
andy
AdrianH - 24/1/11 at 09:16 PM
My original donor was Sierra saffire and also came with 1.8CVH and Type 9 and 3.92 diff
Adrian
avagolen - 24/1/11 at 09:28 PM
As ^^^^
paul@firstmotion - 26/1/11 at 09:19 PM
Gearbox from 1.8 cvh is the same as a 1.6/2.0 pinto with regards to the diff they do vary slightly best thing to do is check the metal tag it will have the ratio stamped on it
Hope this helps
www.firstmotion.co.uk
