Wunoff repackable can sounds like bees playing kazoos!
lordbenny - 2/7/14 at 06:07 PM
Around 4/5000 rpm. I've recently packed some extra wadding in it but annoyingly it still gives off this really annoying buzz especially changing down from high revs. I know it's not the end of the world but me with my OCD and that fact that I hate rattles and knocks really bugs me. How can I pack the can so that it won't buzz?
sjmatthews - 2/7/14 at 06:59 PM
It may be the internal perforated tube that's slightly loose.
lordbenny - 2/7/14 at 07:12 PM
I think you're right....what can I do to fix it?
sjmatthews - 2/7/14 at 07:15 PM
Remove the tube and gently persuade it and where it locates with a hammer so that you have a tight fit when you reassemble it.
lordbenny - 2/7/14 at 07:28 PM
I was just thinking that...I will also plaster it with silicon sealant and pack more wadding in. Thanks
Jenko - 2/7/14 at 08:06 PM
Is the end screwed or riveted on....these can often resonate at certain frequencies...worth checking.
lordbenny - 2/7/14 at 08:19 PM
One end is Allen keys the other is riveted, I now think the noise is definitely the inner tuber being a little loose as mentioned earlier.
dave r - 2/7/14 at 08:41 PM
mine sounds like a swarm when really hot....
i occasionally have to stop and nip the bolts up a bit while its still hot.... tis ok then for a for more miles
