Hi anybody selling 17 crossflow cheers Ali
I've got a 1600 one size overbored. It's got some nice bits with it (steel rocker posts, double valve springs, 264 cam, larger valves). But
it's in pieces. And I'm south of London.
Let me know if you want more info
Bloke in Penrith selling a 1600 that has been stored in a shed for 5 years he was wanting £280
im just about to build up a full new engine
711m block bored and decked.
+0.090" pistons with pockets machined for high lift cam
big valve ported and polished unleaded vulcan engineering head
choice of bcf2/kent 224/234cam
vernier adjustable timing gear
steel rocker gear
new oil pump, water pump, thermostat, sensors.
£2500
as its not built there is some flexiblity in spec/finish
I will shortly be swapping a 1600 crossflow for mx5 power in a locost so the old engine will be available.
It can come as a complete package if wanted with bike carbs, exhaust system and type 9.
