New Topic New Reply
Author: Subject: Exhaust
StrikerChris
posted on 18/11/09 at 03:33 PM Reply With Quote
Exhaust
Hi
Just a quickie,well 2 actually. Firstly has anyone found any magic agents that clean all the burnt on road dirt,horse crap and chavs melted tracksuits off polished stainless exhausts,or is brasso end elbow grease the only answer?!
sedcondly,my silencer is clamped to a pipe i made bolted directly to the turbo,and hence is effectivly solid from the manifold to the single rubber bobbin i'm using to bolt it to the side if the car at the end of the can.No problems as yet,but when its hot the exhaust grows in length 10-15mm,hence stretchin the bobbin.Not the end of the world to replace it every few hundred miles if need be,i'm just interested how others have overcome,or even noticed the heat expasnsion? Any idea's to play with over the winter would be appreciated.
Chris
speedyxjs
posted on 18/11/09 at 03:57 PM Reply With Quote
Number 1 should be cured by brake cleaner or white spirit.
Davey D
posted on 18/11/09 at 04:34 PM Reply With Quote
i sprayed mine with some Autoglym alloy wheel cleaner, and left it on while washing the rest of the car. it seemed to bring it up quite nice, although the really dark bits on the end of the outlet still need some abrasive cleaning like brasso, or autosol
Confused but excited.
posted on 18/11/09 at 05:04 PM Reply With Quote
Cleaning problem........Ask Kim and Aggie
[Edited on 18/11/09 by Confused but excited.]
austin man
posted on 18/11/09 at 06:19 PM Reply With Quote
Farecla polising compound is good for cleaning the exhaust
Toprivetguns
posted on 18/11/09 at 07:50 PM Reply With Quote
I have a cleaner at work called Alko-Bee. We use it to remove burnt oil deposits in Aero-Engine oil pipes.
On a better note its fabulous for car exhaust dirt etc. Not sure if its commercially availiable. Worth a go!
Only drive as fast as your angel can fly... !
StrikerChris
posted on 18/11/09 at 07:59 PM Reply With Quote
hmmm.might have to talk to the chunky girl in supplies in work see if i can get a sample...
New Topic New Reply
