maccavvy
| posted on 10/8/12 at 07:14 AM |
Which fuel pump to use.
Have a oe pinto engine running a 32/36 weber at the mo, this is soon to swapped for a 2.1,gas flowed big valve head and fr32 cam with bike carbs. will
the original mechanical pump run this ,or am i better off with an electric pump.
I know i need a pressure regulator ..do i need a return to the fuel tank as well.
any info appreciated.
Garyd
| posted on 10/8/12 at 08:14 AM |
Hi,
Buy a motorbike fuel pump fit and forget.
No need for a regulator then or a return.
FuryRebuild
| posted on 10/8/12 at 08:15 AM |
Hi
I went through this on my pinto (2.1L, Dave Walker head, REC Race Valves, 44.5mm inlet, 38mm exhaust, Piper A8 cam) which was fitted with a pair of
45mm twin-choke dellorto carbs.
You definitely need an electric fuel pump (the mechanical one won't be rated to the amount of fuel you can drink at full chat) and you need a
pressure regulator (electric one may over-fuel your carbs). They're not expensive.
You don't need a return run - the all the fuel the pump delivers is consumed at the carbs, and the regulator means the pump doesn't supply
too much fuel to carbs that has no-where to go.
I hope this helps.
If you haven't started building yet, my pinto setup is coming up for sale - the head alone would cost over £600 now, the carbs regularly go for
more than £300 on ebay, and the whole lot has been set up and maintained by Bogg Brothers ("it's a right powerful lump is that" .
Getting the engine as a set with the carbs alone would save you £100 on the rollers - it's specifically jetted for this engine. If you're
interested, it comes as a full engine including:
- starter motor
- alternator
- modified alternator brackets - lowered to sit neatly under the exhaust and closer to the engine block
- modified burton rocker cover (removed oil-feed cap housing to reduce height, and opened out breather oil-ways to get engine breathing correctly -
pintos chuck a lot of oil around)
- high performance breather valve
- alloy rs2000 sump (a rare item)
- steel bellhousing and clutch fork (less wide than the alloy one)
- engine mounts
- if you went for the carbs, you could have the inlet manifold
- fury pinto exhaust (blows a tiny bit only when cold)
- a simple thing, but the cam belt anti-jump-off plate - this means you should never lose your cam belt - with this spec that would be a proper
mess
- electronic ignition distributor
- blanked off and removed fuel pump (no mechanical pump supplied). I *may* be persuaded to include the fuel pressure regulator and pacet electronic
pump
- some steel-braided hose for oil lines, etc
- the engine has only ever run on valvoline racing oil, and has 4.5L of it sat in the sump, with less than 200m on the oil
www.furyrebuild.co.uk
mcerd1
| posted on 10/8/12 at 08:56 AM |
most bike carb's don't like running with high pressure fuel being forced into them...
a pump from a bike running carbs are the simplest / cheapest way to sort this as they regulate the fuel pressure themselves
any carb's bike with similar power should have a pump you could use - but it can't be from a fuel injected bike as they run at much higher
pressure.
I got a ZX9R one for mine, some of these are quite neat external pumps on a little mounting bracket with a fuel filter and shouldn't cost more
than £30 - £40 from a breaker / ebay / etc...
(my one is like this one: eBay Item only I didn't pay that much for it)
[Edited on 10/8/2012 by mcerd1]
dray13dad
| posted on 10/8/12 at 04:54 PM |
+1
FASTdan
| posted on 10/8/12 at 05:18 PM |
Hi, as has been said the bike pump is the cheapest, easiest and most reliable. We have a stock and can supply you a pump if needed. :-)
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
deltron63
| posted on 10/8/12 at 08:49 PM |
quote: Originally posted by Garyd
Hi,
+1
