New Topic New Reply
Author: Subject: Tyre pressure when sprinting
pistol pete
posted on 7/2/16 at 08:39 AM Reply With Quote
Hi
My mk runs 205 60 13 and 185 60 13, i am going to run super softs for my sprinting events..
It weighs 500kg wuth a busa engine
What sort of tyre pressures do you recommend to use as a starting point?
Always had the mr2 slightly higher to get them to warm up quickers, its a 1 lap sprint with no tyre warming allowed.
Any advice would help
steve m
posted on 7/2/16 at 12:13 PM Reply With Quote
I have 205/13 on the back, and 185/13 fronts, and run 16/17 psi
this is only road use, but somewhere to sart with
steve
LBMEFM
posted on 7/2/16 at 12:33 PM Reply With Quote
Depends on the tyres, on my MK Indyblade, which weighs a similar weight to yours, On track I use Toyo 888's which I run at 13psi. Contrary to what you would expect, reading a report from Toyo expert on here some time ago, if your tyres get a little too hot then reduce the pressure. With these pressure however the grip is superb.
jeffw
posted on 7/2/16 at 12:47 PM Reply With Quote
What tyres are you running and which class do you intend to run in?
pistol pete
posted on 7/2/16 at 01:47 PM Reply With Quote
Thanks.
I expect ill be running kuhmo v70a super softs..
I usd to run in the Toyota sprit series.. Now move to javeling sprint series class b2 I think
New Topic New Reply
