YOUSAY54
posted on 4/2/19 at 02:49 PM |
cam belt cover.
Hi All have a 1600 pinto in my car with no cambelt cover, what I want to know is 1.6 and 2.0 cover the same size? and do I have to remove anything
around the water pump area to fit, thanks for any help,
posted on 4/2/19 at 05:06 PM |
Might be better posting in the wanted section ? I,ve seen one for sale in the last couple of days but have cleared my browsing history, it may have
been on Facebook in the kitcar and parts for sale/wanted site?
jollygreengiant
posted on 4/2/19 at 05:12 PM |
1.6 and 2.0 cam covers are NOT the same size, unless it is the 1.6Emax then that IS the same size. In the early days they used to stamp 1.6 on the 1.6
cam covers and 2.0 on the 2.0 cam covers (centre of bit that covers the cam sprocket). The difference is in the height of the block. 1.6Emax and 2.0
used the same block (same crank just smaller pistons for the 1.6Emax).
no you don't need to undo anything around the water pump. One pump bolt should be longer than the others, this is what the cam cover engages
onto at the water pump, the one bolt at the bottom of the cover, one below the cam pulley (engages into another longer bolt that secures the tensioner
and a third(/fourth) bolt to the side(s) of the cam pulley. (all from memory as its been a year or two since I played with these).
YOUSAY54
posted on 5/2/19 at 03:07 PM |
cam belt cover.
Thanks for the info, going to leave as is no cover, just have to watch my hands etc
James
posted on 6/2/19 at 11:56 AM |
Having found a stone sitting in the 'v' between the belt and the oil pump pulley can I suggest you fit the cover!
God knows what this would've done to the engine if it'd gone any further!!!
James
- Muhammad Ali
jollygreengiant
posted on 6/2/19 at 05:26 PM |
James
Why worry, I have never heard of a Pinto clattering it's valves when the belt goes. When we used them in Cortina's for taxi's they
never used to fit the covers, always carried a spare belt (and tools to do the job, which was not many) in the boot. Drive the cars until the belt
broke then replace it at the road side and carry on working. It used to only take about 20 minutes.
mcerd1
posted on 6/2/19 at 09:38 PM |
James
^^ I though it was only the std. 2.0 one thats a non-interference engine - the others aren't so safe
posted on 7/2/19 at 08:00 AM |
I’ve had a couple of Pinto lumps bend valves over the years, can’t remember what size engines though,
40inches
posted on 7/2/19 at 09:35 AM |
Not cheap, but cheaper than a replacement engine/ repair I suppose?
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=+pinto+cam+belt+cover&_sacat=0
