Guinness
| posted on 20/5/08 at 05:03 PM |
Council Garage - Lighting - Charging
A mate of mine keeps his Caterham in a "Council" type garage that is part of a block of garages round the corner from his flat.
Trouble is the battery keeps going flat between drives and there is no mains electricity.
So I thought about mounting a trickle charger solar panel on panel above the door (luckily it faces south) and extending the wire inside to the
car.
So far so simple. But I was wondering if the trickle charger could charge a "spare" battery as well. From this I'd run a switch
and a couple of low energy 12v flourescent tubes, so you could see whats in the garage at night!
Anyone know how to wire this up so that 1 trickle charger keeps both batteries charged up, but that having the lights on only runs the spare battery
down, leaving the one on the car ready to go?
Mike
David Jenkins
| posted on 20/5/08 at 05:06 PM |
They don't give a lot of charging current - enough to keep a well-charged battery topped up, but little more.
I don't think they'd charge a battery up from a discharged state...
joneh
| posted on 20/5/08 at 05:38 PM |
http://www.maplin.co.uk/Search.aspx?criteria=solar&source=15&SD
=Y
Won't this do the trick? First result.
David Jenkins
| posted on 20/5/08 at 06:17 PM |
That's the one I've got - bought in Maplins on special offer ages ago.
omega 24 v6
| posted on 20/5/08 at 06:43 PM |
we use them at work as a back up charging system for on board trailer batteries. As already said they will struggle to do the job mate. 2 off around
400mmX800mm certainly are not enough to charge a well flat battery. Sorry
David Jenkins
| posted on 20/5/08 at 06:51 PM |
However, they may well help to stop a fully charged and healthy battery from losing charge over time - which, in all fairness, is all they claim it
will do.
Bigheppy
| posted on 20/5/08 at 06:56 PM |
I bought a generator cost £39 but I have recently seen em at car boot sales /markets for £35. This would enable you to use tools as well as lights.
The solar charger would then be perfect to keep your battery charged.
owelly
| posted on 20/5/08 at 07:30 PM |
I know of dozens of folks who used these solar panels to keep the battery topped up on boats (there was a BOGOF offer in some boaty magazine).
Consequently, there were dozens of these things littering the skip outside the boatyard. You need to keep the battery topped up for when the bilge
pump wants to play.
I tried one from Maplins a few years ago and it failed to overcome the current drawn from the digital clock on my car......
http://www.ppcmag.co.uk
| posted on 20/5/08 at 07:39 PM |
I use an inverter to power a couple of 5 foot lights from a12v battery which seem to last fairly well between charges. Jump pack for starting the car
if needed. Perhaps he should use the car more often or get the battery and charging system checked? Painting the walls and fitting plaster board
sheets help with the lighting
David Jenkins
| posted on 20/5/08 at 08:14 PM |
I must admit that mine has been on top of a shelf in my garage for the past 2 years, so I'd best keep quiet...
[Edited on 20/5/08 by David Jenkins]
britishtrident
| posted on 20/5/08 at 08:17 PM |
LED lighting is the most energy efficient by a very large margin --- but you don't get much light.
[/I]
omega 24 v6
| posted on 20/5/08 at 08:57 PM |
Times have moved on a bit and we use these.
,Labcraft s 13 LED int lights
They aint cheap but 4 of them make the inside of a 40ft artic look like daylight. Strange thing is that during daylight they don't look up to
the job but believe me they are
| posted on 20/5/08 at 09:22 PM |
I've looked into in the past and the solar panels don't make enough juice for anything other than topping up the car battery unles
you're prepared to spend serious cash on panels....
