greggors84
posted on 2/4/09 at 07:07 PM |
Corner weights and percentages
Going to set the car up on the flat patch this weekend. When people have had their cars set up by companies in the past how close have they got your
front corner weights and what percentage front and rear.
While im here asking what cambers and toes should I be going for?
From reading here im thinking 1-2mm toe in on the front and parallel on the rear?
Chris
The Magnificent 7!
mr henderson
posted on 2/4/09 at 07:25 PM |
Sounds pretty good to me, maybe a degree of negative camber as well. Then take it for a drive and see if you like it. Corner weights are worth doing
if you have the equipment, but I don't think they are as important as the other paramenters, unless they are grossly out
How will you simulate your own weight, or do you have someone who can sit in for you
John
greggors84
posted on 2/4/09 at 07:48 PM |
We have an old set of Longacre scales sitting there at work begging to be used! Would be a shame not to!
I doubt I would notice the difference even on track. Its not something I would pay to be done as long as they are vaugely close. As for weight I would
just get someone similar to sit in the car while I made the adjustments, or vice versa if im feeling lazy!
Also after chatting to the Mac1 guys about weight and with lots of numbers flying about would be interesting to get an actual figure on it.
[Edited on 2/4/2009 by greggors84]
Chris
The Magnificent 7!
sorens2
posted on 2/4/09 at 08:44 PM |
John
Sit the scale next to the driver seat and you won´t need an extra mechanic.
Soren S2
[Edited on 2/4/09 by sorens2]
greggors84
posted on 2/4/09 at 09:37 PM |
Yeah, but if i stay in the seat I can get nice and comfy while someone else does the work!
Chris
The Magnificent 7!
