david
| posted on 5/6/09 at 10:29 PM |
wilwood powerlites
I have a set of wilwoods that were fitted to my MK ,sierra uprights. Can I get the plate that holds the disks onto the sierra uprights with a plate
that suitable for a cortina setup. The alloy bolt plate holds the top and bottom of the wilwood caliper and the other two bolts bolt on to the
upright bracket. Hope this makes sense.The difference in the bolt holes is not a lot. Where is there a good place that knows about wilwoods etc.David
james h
| posted on 5/6/09 at 11:06 PM |
Phone rallydesign. They are the European distributer for wilwood, and IIRC there are brackets on there for cortina
uprights.
HTH
James
Ray
| posted on 21/6/09 at 09:03 PM |
Burtons will also do the brackets you need
cheers Ray
