New Topic New Reply
Author: Subject: 32/36 dgv mod
gjn200
posted on 9/4/04 at 11:08 PM Reply With Quote
32/36 dgv mod
Would this work?
Adapting the linkage (easy to do) so that the 2nd barrel opens at 1/3 throttle instead of 2/3??
<- Me!
posted on 10/4/04 at 10:56 AM Reply With Quote
It would probably use a lot more fuel for no visible effect if you pile fuel in without enough air to mix with it and cause a massive flat spot. They know what they are doing at Weber.
MikeR
posted on 24/5/04 at 11:59 AM Reply With Quote
Its my understanding that the carb is trying to keep the engine fuelled at the perfect level for combustion all through the rev range (ok, I know that carbs aren't perfect).
Unless you've got a modified engine modifying the carb like you suggest will probably make it run worse. If you have got a modified engine then a rolling road would be a much more expensive but better option.
Too little petrol will make the engine over heat, too much washes the oil from the bores and you get bore wear. Either way, it can be expensive on the rebuild
NS Dev
posted on 29/5/04 at 09:24 AM Reply With Quote
far simpler and easier to just press the accelerator 2/3 instead of 1/3!
Surrey Dave
posted on 17/7/04 at 06:32 PM Reply With Quote
Or
fit a DGAS both chokes open together on that one.......
[Edited on 17/7/04 by Surrey Dave]
ch1ll1
posted on 12/10/05 at 08:14 PM Reply With Quote
dgas is the best option !
or just fit some twins
ayoungman
posted on 3/11/05 at 12:13 PM Reply With Quote
I looked into this last year when I got my weber. Many people in the past have tried to modify but few if any were successful. The capri owners and RS club sites are useful sources of info for this sort of stuff. Remember, this stuff has been around for 20 to 30 years so the old owners clubs have....... been there/seen it/done it all before ! HTH
"just like that !"
New Topic New Reply
