ricklawn
posted on 14/4/08 at 07:09 PM |
r6 bike carbs
Hi guys
Going up to bogg bros in the morning. i have a set 2005 r6 carbs ( 2005 they changed to 38mm chokes). question is they are from an injected model.
Have i dropped a dangly thing and bought the wrong ones?
Rick
big_wasa
posted on 14/4/08 at 07:12 PM |
Do they have injectors ?
ricklawn
posted on 14/4/08 at 07:16 PM |
yes everything including all pipes and electrics
posted on 14/4/08 at 07:17 PM |
Do they have a choke ? , float chamber? if so they are carbs if they have injectors in each with an electrical connection probably 2 pins connected by
a common fuel rail they are throttle bodies
ricklawn
posted on 14/4/08 at 07:33 PM |
just put 2 pictures in my folder (sorry rather large) top 2 pictures..are they ok for 1.8 zetec?
lsdweb
posted on 14/4/08 at 07:44 PM |
They are throttle bodies and ideal if you're going down the injection route....
If you want carbs, I think there may be somebody on here who may be interested in buying your throttle bodies off you.
Paul TigerB6
posted on 14/4/08 at 07:49 PM |
As above - they are throttle bodies and in 2005 went up to a 40mm choke from 38mm.
Have you bought all the other bits for a carb setup yet?? Personally i'd stick with the TB's and get a MegaSquirt n Spark to run them.
I'm sure you could sell them easy enough through here though if you really want to stick with carbs - would that cause a problem with you going
to Boggs tomorrow though as i assume you were getting them rejetted there??
[Edited on 14/4/08 by Paul TigerB6]
ricklawn
posted on 14/4/08 at 07:55 PM |
what sort of money and problems would fitting megasquirt
ta
