New Topic New Reply
Author: Subject: Turbo noise and lack of boost
madteg
posted on 9/6/08 at 07:36 PM Reply With Quote
Turbo has broke, looks like bearings worn out impellar is touching the side of housing creating squeal, but impeller has fins missing. Where have they gone.
posted on 9/6/08 at 07:37 PM Reply With Quote
They've turned into noise, smoke and heat....
Volvorsport
posted on 9/6/08 at 07:38 PM Reply With Quote
most likely lying in your intercooler somewhere .
www.dbsmotorsport.co.uk
getting dirty under a bus
graememk
posted on 9/6/08 at 09:06 PM Reply With Quote
i used a place in goole that rebuild my turbo for £300 turned it into a hybrid
stevec
posted on 9/6/08 at 09:16 PM Reply With Quote
I would also be looking for what possibly entered the turbo to cause the damage before fitting a replacement unit.
Steve.
graememk
posted on 9/6/08 at 09:28 PM Reply With Quote
yep very good point, must be a bit of manifold missing
Steve.
tegwin
posted on 9/6/08 at 10:13 PM Reply With Quote
Is it not possible that bearing failiure (due to oil starvation proberably) caused the compressor to catch on the casing and shatter off sending bits into the intercooler?
Im no expert, but even a slight nudge of the hot turbine/compressor onto the stationary walls must put a huge force on the parts
www.verticalhorizonsmedia.tv
New Topic New Reply
