New Topic New Reply
Author: Subject: Considering Fully Flat Floor - any tips?
hobbsy
posted on 22/6/08 at 10:26 PM Reply With Quote
I'm considering going for a fully flat floor on my Fury.
If I understand correctly the main benefits are reduced drag and reduced lift.
At the moment only the seat areas are panelled so all under the engine, transmission tunnel and diff & petrol tank etc are exposed.
What thickness of ally sheet should I use - won't be standing on it like the main floor and I don't want to add too much weight.
Also I guess it would be useful if its removeable so are rivnuts the best bet (M5?)
The sump is still going to stick out so dropping the oil won't be any more diffcult but oil filter access could be.
Any tips appreciated.
Oh and where is the best place to buy sheets of aluminium? I'm in Northampton.
DavidM
posted on 22/6/08 at 10:31 PM Reply With Quote
Try:
ASC Metals,
Crow Lane,
Billing
http://www.applegate.co.uk/engineering/company/co_1063646.htm
Proportion is Everything
chrsgrain
posted on 23/6/08 at 08:55 AM Reply With Quote
Watch out for engine bay temperatures.... nowhere for the air to get out if its fully paneled.
Chris
procomp
posted on 23/6/08 at 09:02 AM Reply With Quote
Hi yep engine bay temps will need to be checked and vented if problems. Also Diffs can be a problem. On the race cars they will do a 1/2 hour race just. But if testing for longer periods they overheat. Meaning venting and cold air feed is nesercery.
HTH cheers Matt
scoop
posted on 23/6/08 at 09:18 AM Reply With Quote
I was advised to use 1.6mm by my Lotus friend. Dont want too much weight as you say
adithorp
posted on 26/6/08 at 07:44 PM Reply With Quote
I'm planning the same thing. I'm going for 1.6mm and I'll fasten it with 5mm capheads. I'm going to put an NACA duct in the tunnel section to feed some cool air to the diff', a vent in each side of the bonnet and 2 vents in the indentations on the top of the LeMans bonnet.
adrian
posted on 3/7/08 at 10:29 AM Reply With Quote
HTH cheers Matt
A trick used by short oval Hot Rod racers with the english axle was to cool the diff oil by pumping it out via a electric bilge pump through a length of copper pipe then back to the diff --- it was just enough to cool the diff without a cooler.
New Topic New Reply
