Author: Subject: SVA Ready MNR (hopefully!)
spdpug98
posted on 25/4/09 at 06:14 PM Reply With Quote
Well after 12 weeks since I got the kit I think she is finally finished, please have a look through the usual pics and let me know if I have missed anything.
I know that I still need to sort the steering wheel and also the rear harness mounts, but is there anything else I have missed
My Blog: http://spdpug98.wordpress.com/
Steve Hignett
posted on 25/4/09 at 06:16 PM Reply With Quote
You seem to have Mummified your exhaust!
Only kiddin' Mate, looks great - best of luck with SVA etc
blakep82
posted on 25/4/09 at 06:19 PM Reply With Quote
wish bone rose joint lock nuts might need covering?
awesome job in 12 weeks though!
________________________
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 25/4/09 at 06:21 PM Reply With Quote
12 Weeks!! Crikey!
I love the centre console, looks great!
I presume a wonky indicator isn't a fail - though make sure it doesn't look 'too temporary'.
Nice colour too btw
bassett
posted on 25/4/09 at 06:25 PM Reply With Quote
Hi dave, looks good even in its SVA trim. Seat belts are at the wrong angle unless you have adequate flooring to secure them with or put around side of seat. Are reflectors secure and above 350mm? Pipe lagging wont do on dash bar, if thats what it is as long as its radiused and blunt will be ok. How dense is foam around clock? Instructor said mine had to be dense as a pencil rubber but depends on how much is exempt from the 127mm allowance from steering wheel edge. Take some rubber u trim if you need to glue it on the corners. Never came up in mine but handbrake may need a gaitor. How did your emissions testing go?
All the best with the test.
Adam
MK chippy
posted on 25/4/09 at 06:33 PM Reply With Quote
Alright mate!
Car looks mint for 12 weeks work!
so when are you coming up to finish mine then?
Dave
spdpug98
posted on 25/4/09 at 06:34 PM Reply With Quote
Thanks for the replies, some other bits to look at
Adam - I think the emissions are OK now I did melt his analyser probe!!!! At what revs do they check the fast idle levels
My clock cover is quite dense, but the one I was going to use didn't arrive in the post so it is a last minute cover - hopefully it will be OK
spdpug98
posted on 25/4/09 at 06:36 PM Reply With Quote
Originally posted by MK chippy
Alright mate!
Dave
The payback I will have to give to my Mrs will keep me busy for a lot longer than 12 weeks - but will try and get up to see you in the car IF it passes
[Edited on 25/4/09 by spdpug98]
Pdlewis
posted on 25/4/09 at 06:52 PM Reply With Quote
if you can put some heat mat on the passenger rear wing do it as my can has the same exit as yours and because the speed and emmisions test are done still the heat softended the gel coat and i now am missing 3mm by 50mm of the bottom of my wing
Build Photo Album
Updated 05/02/2009
spdpug98
posted on 25/4/09 at 07:02 PM Reply With Quote
Funny you should mention that, after trying to sort the emissions today it is already badly pitted and was going to be my reason to buy some carbon stone guards
neilj37
posted on 25/4/09 at 07:22 PM Reply With Quote
I would have said that the seat belt mounts look a bit low were they attach behind the seats.
slimtater
posted on 25/4/09 at 07:29 PM Reply With Quote
Very nice - I really like the MNR!
http://www.picturetrail.com/sfx/album/view/19919222
Valtra
posted on 26/4/09 at 02:08 PM Reply With Quote
nut covers on headlamps are missing by the looks of it ....Awsome job in 12 weeks fantastic looking car
"If it looks like it works and it feels like it works, then it works"
