prelude1980
| posted on 7/8/09 at 08:39 PM |
Diff Clunk
It's probably been posted lots of times, but my diff is clunking a bit when you initially take up bite on the clutch, and when rolling slowly,
is there anything i can do?
Or is it just a case of use it till it breaks, then put another one in?
Also if it breaks what will it do while i'm driving???
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
eccsmk
| posted on 7/8/09 at 09:03 PM |
mine does that too
has since it was installed
its play it the diff and i think it can be shimmed to remove the play
but it gives a little forgiveness so im leaving mine as it is
| posted on 7/8/09 at 09:31 PM |
Obvious but first thing is check the propshaft bolts are tight and check the shaft UJs
prelude1980
| posted on 7/8/09 at 10:01 PM |
all bits are nice and tight so to speak, it's definately play in the diff
gets you.
LBMEFM
| posted on 8/8/09 at 05:27 AM |
I have seen this posting many times, I too was concerned when I had mine on jacks checking the speedo operation. The clonking and banging on the diff
and prop etc were horrible, but I was told this was quite normal especially BEC,s. Barry
prawnabie
| posted on 8/8/09 at 06:47 AM |
It is "common" in becs not "normal" lol The pinion should have very little or no play in it when engaging the crownwheel if
set up properly.
Mark Allanson
| posted on 8/8/09 at 09:00 AM |
Most (even new) diffs do this, just in a nice cosy insulated tin top you cannot hear it. In a raucous se7en, with the diff 9" from you bumhole
its a different story.
| posted on 8/8/09 at 09:37 AM |
Yup. Mine does it too. Hasn't broken yet......
mangogrooveworkshop
| posted on 8/8/09 at 11:08 AM |
Same as mine scotlads red mk did it and every bec I driven clunks.
The trt prop reduces it but not a lot
prelude1980
| posted on 8/8/09 at 12:30 PM |
looks like i'll leave it then, as this does seem a bit on the comon side.
gets you.
