miikae
posted on 15/9/09 at 05:11 PM |
Type 9 speedo take off measurements wanted
I am going to fit a electronic speedo impulse sender to the type 9 gearbox but its well boxed in, so i wonder if anyone can give me some measurements
useing the gearshift top plate as a refferance point , Xmm down and Xmm forward etc , so i can then use a large hole cutter to gain access before
fitting the sender unit.
I have got a spare Rocket box but not sure if the dimensions would be the same.
The reason for doing this is that magnets i have on the diff flange are ok up to 70mph but over that the speedo readings seem to give a lower reading
and not too stable when dropping speed after either.
Mike
If it can be done it i will be done .
MautoK
posted on 16/9/09 at 10:33 PM |
Here's a pic for you, Mike.
Type9 Side View
HTH
John.
miikae
posted on 16/9/09 at 10:44 PM |
Many thanks for that John, that should make things a bit easier , X markes the spot then drill a 3" hole in the tunnel in the morrow, it looks
like it maybe the same position as the Type E Rocket i have as i checked it out today & it looks like they may well be the same.
Mike
MautoK
posted on 16/9/09 at 10:45 PM |
...then I re-read your msg, so here's what you're after, I hope:
Type9 Side View 2
John.
miikae
posted on 16/9/09 at 10:49 PM |
Thanks again John you are a star.
Mike
