john77cars
posted on 23/9/09 at 07:04 PM |
makeing your own paddleshift system
has anybody made there own paddleshift system,it doesnt look that hard to do,any pictures or advice on how to go about,im after makeing one my self
because they seen a bit pricey for what they are.
Steve Hignett
posted on 23/9/09 at 07:17 PM |
I've never got any good photos to show anyone, but yes it is very simple... Here's a couple of (bad) pics of my polished/drilled Ali and
Carbon Fibre one...
minitici
posted on 23/9/09 at 07:20 PM |
![](/galpreviews/paddles3_1.jpg) ![paddleshift](/gallery/paddles3_1.jpg) paddleshift
Here is mine.
I have not got a decent picture of it on the car yet.
Got andyw7de to waterjet the paddles.
SPA "D" shaped wheel on a quick release boss.
SPYDER
posted on 23/9/09 at 08:21 PM |
Here's our effort in 4mm Titanium. All CNC machined.
There are loads of threads on this subject. Do a search. People have used ali, mild steel,carbon, you name it. Water jet cut, laser cut, hacksaw cut
and filed,etc.
Cable or rod operation?
Use whatever method and material you can afford and that you can find locally.
Tell us where you are, someone may be able to recommend local help.
Geoff.
![](http://i143.photobucket.com/albums/r134/westfield_photos/P1010053.jpg)
adithorp
posted on 23/9/09 at 09:13 PM |
I made my own. I went with thinner ally than most use and reinforcing strips behind. Mainly because it was easier to work...and it's what I had.
I found be most important thing was reducing flex both in the paddle itself and the linkage.
http://i189.photobucket.com/albums/z282/adrianthorp/Picture036.jpg
http://i189.photobucket.com/albums/z282/adrianthorp/Picture034.jpg
http://i189.photobucket.com/albums/z282/adrianthorp/fury086.jpg
adrian
http://jpsc.org.uk/forum/
YQUSTA
posted on 23/9/09 at 11:08 PM |
What may make a difference to the posts above is if you have and want to keep the switch gear on.
The way I did mine was to use the shroud mounting points to mount the plate to allow the paddles to move.
![](/galpreviews/paddles1.jpg) ![Description](/gallery/paddles1.jpg) Description
I do have more pictures of the whole setup if you would like them U2U me and i will sort them out.
Its not hard to do as with any thing else its just a matter of taking your time. I did alot of drawing on paper cutting out and seeing how it looked
behind the ssteering wheel and how easy it would be to use.
it is actually fantastic I still have some minor mods to do to the system to move the paddles further away from the wheel but apart from that its
fine, I also run it via a cable system and have kept the stick shift working which uses a rod system.
locoboy
posted on 24/9/09 at 06:28 AM |
Here is mine, propper locost style at about £8 all in i think.
May not look as flash as a carrbon / titanium/unobtainium version bit it does exactly the same job!
Its made out of push bike handle bar tube with a pair of those forward facing pushbike handle bar extensions you see on mountain bikes.
All sprayed up black it loos fine to me.
[img][/img]
Locoboy
iank
posted on 24/9/09 at 03:22 PM |
See this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=120866
Anonymous
SPYDER
posted on 24/9/09 at 08:51 PM |
Don't forget, should you choose cable operation, to pay particular attention to the cable mounting brackets. They need to be as rigid as
possible at both ends.
We have used a fabricated ally bracket at the paddle end, bolted to the chassis through welded in tubes. You could probably lift the car with it!!
The lower end is fabricated titanium. We just happened to have some offcuts lying around. And we get all our titanium for free (from the scrap bin) so
it's genuinely Locost.
I've seen some woefully flimsy contrivances that will ruin your efforts to achieve a crisp and positive gearchange.
Although we have used a cable setup I feel that a correctly engineered rod type setup might give the best change.
I got talked into using a cable.
Not wishing to open up the "cable versus rod" debate though. It's been done before.
The search button is your friend. You'll find lots of pics for inspiration.
Geoff.
john77cars
posted on 24/9/09 at 09:01 PM |
thanks for all the info
