graememk
| posted on 10/2/10 at 11:49 PM |
digi dash recomendations
i want a clean dash in my car, i have a bright 6 but dont mind if the digi dash has the warning lights built in as i dont have to use the bright 6.
what do you suggest for a cec
bbwales
| posted on 11/2/10 at 12:06 AM |
Hi I have used a Koso XR/SR see http://www.digital-speedos.co.uk/ It fills my needs and is a nice compact unit with speedo, tacho, fuel gauge, water
temp.
Hope that helps
Bob
bj928
| posted on 11/2/10 at 12:54 AM |
i want to go with the dash2 http://www.race-technology.com/dash2_2_31.html
Angel Acevedo
| posted on 11/2/10 at 04:27 AM |
Acewell
I will be using an acewell,,
It is Very Small, but I LIKE IT!!
Russbost has them.
mmm
Mine lacks water temp.
But I wet for Acewell plus Oil press, Water Temp, Voltage and Fuel level separate.
There are Acewell units that have Fuel Gauge too, But I wanted a separate gauge for gas.
jeffw
| posted on 11/2/10 at 05:03 AM |
I had a Trailtech Veypor which was pretty good for the money but I am replacing it with a Koso RX2n+ 10K which has a analog tacho.
http://www.digitalspeedos.co.uk/digital_gauges.htm
iank
| posted on 11/2/10 at 07:43 AM |
Depends what you want from it really.
Acewell/Kosa are small and cheap
If you want some datalogging it might be worth looking into this one
http://www.locostbuilders.co.uk/viewthread.php?tid=129763
Anonymous
flak monkey
| posted on 11/2/10 at 07:54 AM |
Depends what you want I guess.
Not a fan of the cheaper digi dashes, I think they are too plasticy and dont think they look very good.
Take a look at the AIM dashes. The MXL starts at about £700, but you can pick them up secondhand for around the same money as the DD2 lite.
http://www.aim-tec.co.uk/pages/car/section_car_mxl.htm.html
They all do datalogging and you can use all your existing sensors, then some. Or if you are runing a std ecu you can just connect to that with CAN or
RS232.
Sera
http://www.motosera.com
franky
| posted on 11/2/10 at 08:50 AM |
Same here, I'm not a fan of acewell/koso either. Have you had a look for a used stack one? You can't beat having an analogue rev
counter either.
irvined
| posted on 11/2/10 at 11:04 AM |
I'm going for the ETB digidash, you can get a full data logging version, or a cheaper instrument only one. As mentioned above, you can't
beat a real rev counter, so budget for one of those too.
The stack ones are *nice* too.
http://irvined.blogspot.com
turbodisplay
| posted on 11/2/10 at 11:21 AM |
I`ve designed a dash which has warning lights built in.
It has inbuilt data logging.
Look at www.tdash.co.uk
Darren
eddie99
| posted on 11/2/10 at 11:33 AM |
I went for an Acewell of Russbost, Yep not the best and dont compare to the £500+ but for £100 doing everything you need, its a bargain!!!
AdamR
| posted on 11/2/10 at 02:08 PM |
The Race Technology Dash 2 is one of the best. I very nearly got one... before deciding
analogue was the way forward.
beaver34
| posted on 11/2/10 at 06:51 PM |
ive just purchased one of them, fantastic bit of kit
bigfoot4616
| posted on 11/2/10 at 08:27 PM |
quote: Originally posted by irvined
As mentioned above, you can't beat a real rev counter, so budget for one of those too.
i've got the ETB digidash, don't really see the need for an analogue rev counter as the shift lights tell you all you need to know
i always have revs in the LED section which is easy enough to read.
T66
| posted on 13/2/10 at 10:29 AM |
I have a Koso RX1 -
Small - good spec
Everything you need in one bundle, and not too expensive.
