New Topic New Reply
Author: Subject: Which paint?
cerbera
posted on 23/7/10 at 11:23 AM Reply With Quote
Which paint?
Had the car MOT'd yesterday and while it was over the pit I took the opportunity to have a good butchers underneath.
I noticed, in a few places, some light rusting on the chassis which I want to remedy. So, what's a good durable brush on paint to use?
Ta.
cerbera
posted on 23/7/10 at 11:39 AM Reply With Quote
Anyone tried this?
rgrs
posted on 23/7/10 at 11:45 AM Reply With Quote
Yes it's very good covers well but in the small print does need a topcoat of something else.
A small tin does go a long way provided you brush paint, also you need the correct thinners as well.
Roger
MK9R
posted on 23/7/10 at 12:42 PM Reply With Quote
Roger
I've used it without a top coat, excellent stuff and sticks like bear sh*t to a rabbits back!!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Canada EH!
posted on 23/7/10 at 02:02 PM Reply With Quote
It only needs a topcoat if exposed to UV, so unless you intend to get the dity side up, it shouldn't be a problem.
Daddylonglegs
posted on 23/7/10 at 03:50 PM Reply With Quote
Chassis paint seems OK as long as it's put on a clean surface and a couple of coats.
cerbera
posted on 23/7/10 at 06:46 PM Reply With Quote
Cheers chaps
ShaunB
posted on 24/7/10 at 10:29 PM Reply With Quote
It's very good stuff. It's sticks very well including to skin and will not some off once dried - wear gloves!!
New Topic New Reply
