Craigman9
| posted on 2/4/11 at 12:54 PM |
Temporary fix needed!
Hi Guys,
I have a very very small hole on one of the welds for my shortened sump. I know that it will have to be taken off and repaired at some point via
welding.
Does anybody have any suggestions as to a temporary fix for stopping the oil leak until I can get it fixed?
mangogrooveworkshop
| posted on 2/4/11 at 01:09 PM |
clean with acetone and stick some metal weld epoxy on it
UncleFista
| posted on 2/4/11 at 01:10 PM |
Rub a bar of soap into the hole (it blocks the hole long enough to repair), then wipe clean and cover with epoxy
It worked as a temporary fix for us to get us the couple of hundred miles home 3 years ago (ours was quite a bad one) it's still there, leak
free
Tony Bond / UncleFista
dave-69isit
tank fix should do it
| posted on 2/4/11 at 02:03 PM |
Petro Patch.
lotusmadandy
| posted on 2/4/11 at 06:27 PM |
Do a temporary repair with some JB weld or similar,then
bring it up to my house and i will weld it
for you mate.
[Edited on 2/4/11 by lotusmadandy]
Craigman9
| posted on 2/4/11 at 06:30 PM |
Cheers Andy
We are going to have to get the cars out sometime soon!!
907
| posted on 2/4/11 at 07:14 PM |
If it's a round pin hole in a weld then a dot punch works.
Balming goo all over it just makes it hard work for the welder.
Paul G
Ninehigh
| posted on 2/4/11 at 07:19 PM |
Ductape
