Author: Subject: Curious starting problem
smac
posted on 3/7/11 at 04:18 PM Reply With Quote
Just had a day at Harewood Hillclimb (excellent). Parked the car in the field at the top and left it in the blazing sun all afternoon. Came back, put the key in and nothing - no click no attempt to turn over whatsoever. Some friends had some jump leads so we tried them but it was no different. Ended up bump starting it and driving the 5 miles home with no problems. when i got it back in the drive it started first turn of the key as usual. Ive discounted a battery fault (perhaps wrongly) on the grounds that the jump start didnt work - what else could it be?
Simon
Dusty
posted on 3/7/11 at 04:24 PM Reply With Quote
Pointing up hill. Fuel vaporised and pushed the liquid fuel back to the tank?
Re-read the symptoms. Heat - some metal expanding in relay or switch - failed switch.
[Edited on 3/7/11 by Dusty]
smac
posted on 3/7/11 at 04:26 PM Reply With Quote
It wouldnt actually turnover at all so fuelling wasnt the issue
perksy
posted on 3/7/11 at 04:28 PM Reply With Quote
Immobiliser issue *If* you have one ?
Worzey
posted on 3/7/11 at 04:44 PM Reply With Quote
Starter motor?
Caterham R400
big_wasa
posted on 3/7/11 at 05:13 PM Reply With Quote
Some kind of bad contact. Sierra ignition switch ? they pack up and can go intermitant.
posted on 3/7/11 at 05:30 PM Reply With Quote
Are you using a relay for the starter solonoid? Could be the ignition switch or the starter. If/when it happens again try bridging the main battery connection to the wire from the ignition switch if the starter works the problem is in the switch/wiring if not then suspect the solonoid/starter. Had the same problem 3 times in 13 years with my old Citroen XM, never did find it
