New Topic New Reply
Author: Subject: Cheap Tyre Pyrometer??
mikeb
posted on 14/7/11 at 04:46 PM Reply With Quote
Whats the cheapest option.
£128 quid seems a lot for a multimeter and a thermocouple!
posted on 14/7/11 at 05:03 PM Reply With Quote
I have used an IR thermometer in the past, similar to this one from Maplins:
Maplins thermometer
I know it's not the same, but it's good enough to tell me whether the outside edges are hotter/cooler than the middle. If you get within an inch or so of the tyre surface they're pretty accurate.
Neville Jones
posted on 14/7/11 at 05:08 PM Reply With Quote
I've been using a Maplins UT58 series(N79CB) from Maplins. It comes with a couple of probes.
The IR measures surface temp, which can be significantly lower than the temp just under the surface, particularly after a slow down lap.
Nev.
mikeb
posted on 14/7/11 at 05:45 PM Reply With Quote
So the maplin unit comes with suitable probes?
Is there a reason demon tweeks want £60 just for the probe?
Neville Jones
posted on 15/7/11 at 10:06 AM Reply With Quote
Greed, excessive profits, and there's a mug born every minute.
The maplin thermocouple is £3.59. Similar thing!!!
http://www.maplin.co.uk/k-type-metal-thermocouple-46257
My Maplin meter came with a standard thermocouple, a probe thermocouple, and a set of standard test leads. Been using it for a few years now, and is as accurate for the job as needs be.
Nev.
mikeb
posted on 15/7/11 at 10:34 AM Reply With Quote
Chatting to Avon they say you need to get the probe right into the tread so it needs to be pointy.
Does the maplin one do the trick, it look a bit blunt?
mikeb
posted on 15/7/11 at 10:50 AM Reply With Quote
Think I need a probe like this
http://www.tcdirect.co.uk/deptprod.asp?deptid=135/7
would like to find one cheaper though.
Wonder if you could make the mapline one more pointy without wrecking it?
mikeb
posted on 15/7/11 at 11:09 AM Reply With Quote
What the cheapest multimeter that will take a k-type thermocouple with the yellow connector (not the two banana plugs that are standard on teh cheap ones?)
M
Neville Jones
posted on 15/7/11 at 04:31 PM Reply With Quote
I just sharpened the end of mine to about 90degrees angle, with a file. For £3.59 a go, I figured it was worth a try.
RS have a number of K thermocouples under £20, and as many above as well.
Nev.
New Topic New Reply
