New Topic New Reply
Author: Subject: K SEAL
spiderman
posted on 18/1/12 at 01:44 PM Reply With Quote
K SEAL
Hi Guys,
Has anyone used K Seal for rad or head gasket leaks, and if so would you recommend it?
Cheers.
Spider
blue2cv
posted on 18/1/12 at 01:49 PM Reply With Quote
Found one recently called Steel Seal, tried and it works, i was sceptical, but so far so good
posted on 18/1/12 at 02:02 PM Reply With Quote
I've used K-Seal for a heater matrix leak and it worked perfectly.
PSpirine
posted on 18/1/12 at 02:26 PM Reply With Quote
Used K-seal for a tiny head gasket leak - did bugger all. Although it does make your coolant pretty and glittery. It does tend to deposit a sludge in low pressure areas along the coolant system (on mine it clogged up a few bits, but only slightly).
I'd probably use it for a rad/heater matrix repair, but don't bother if it's a head gasket.
mookaloid
posted on 18/1/12 at 02:58 PM Reply With Quote
I had a split in a plastic rad header and it did nothing for that.
clairetoo
posted on 18/1/12 at 05:40 PM Reply With Quote
I used it for a leaking head gasket on my Corsa (it was drinking all its water in about a week) , that was nearly a year ago and I havnt had to top it up since !
Its cuz I is blond , innit
Claire xx
Will weld for food......
Thinking about it
posted on 18/1/12 at 08:37 PM Reply With Quote
it's a bodge. Best to repair what is wrong.
I bought a car that it had been used on. It had blocked up what it needed to but also blocked up some valves.
It took ages to get the cooling system back to as it should be.
I would put it in the same class as putting thick oil in a knackered diff or gearbox.
posted on 18/1/12 at 08:53 PM Reply With Quote
K seal (1) works provided you are not asking it to stop a massive leak (2) won't cause any problems.
Other radaiator leak sealers are likely cause trouble on modern car especially of some Honda models which have tiny bore coolant passages in the head. ---
Bars leaks will choke waterways, Radweld can cause thermostats to stick closed.
[Edited on 18/1/12 by britishtrident]
spiderman
posted on 19/1/12 at 05:20 PM Reply With Quote
Thanks for the info folks. I suppose I will have to try it and see if it works as the only downside is that it may not work. Leak is a small pinhole in the rad. The rad is on a mates bike and I suggested using this rather than paying £180 for a new rad. I will also enquire if it can be repaired and the cost involved if it can. I was just being cautious as it's not my bike and did not want to cause him more bother, if it was mine I would have tried it straight away.
Once again many thanks to the folks on this forum which is the best I have ever come across.
Spider
posted on 19/1/12 at 06:37 PM Reply With Quote
A blob of Araldite then some K seal
New Topic New Reply
