jlayton
| posted on 8/5/12 at 05:32 PM |
tracking
just finished building my mk, but need to know like a base setting for the tracking. any info would be great
cheers
dhutch
| posted on 8/5/12 at 05:47 PM |
cheers
Im sure others will comment, but somewhere between zero and 1deg appears common in the kitcar world.
| posted on 8/5/12 at 05:50 PM |
1 Degree is a hell of a lot of toe in IMHO
phelpsa
| posted on 8/5/12 at 06:03 PM |
When I was on radials I ran 30-45' toe in rear and 15' toe in front.
[Edited on 8-5-12 by phelpsa]
jlayton
| posted on 8/5/12 at 08:16 PM |
if 1 degree is to much what should i be looking for realy, so i can get it to drive pretty reasonable
cheers
ReMan
| posted on 8/5/12 at 08:37 PM |
1-2 deg should be fine on an MK
www.plusnine.co.uk
jlayton
| posted on 8/5/12 at 08:41 PM |
cheers il try that as soon as the weather picks up
phelpsa
| posted on 8/5/12 at 09:04 PM |
1-2 deg of what? Thats an enormous amount of toe!
ReMan
| posted on 8/5/12 at 09:10 PM |
1/2 that better?
Anyway it makes no differnce does it with a floppy chassis and no caster
www.plusnine.co.uk
PAUL FISHER
| posted on 8/5/12 at 09:24 PM |
A good starting point for the Indy would be,-2 degrees front camber -1.5 degrees rear, I ran mine at 0.5 degrees tow in, mainly a track car though,
ride height should be about 115mm front 120mm rear
phelpsa
| posted on 8/5/12 at 09:28 PM |
1/2 that better?
If you mean toe-in then that makes more sense!
Chippy
| posted on 8/5/12 at 10:13 PM |
Measuring front and back of the wheel, I set mine to just 1 to 2mm of toe, seems to be about right, but then mine isn't an MK. But HTH Ray
whitestu
| posted on 9/5/12 at 06:46 AM |
I have half a degree toe in on mine at the front.
The rear also has half a degree toe in but any changes to that would need shims.
