madteg
posted on 4/9/12 at 06:39 PM |
Sierra LSD oil change
Wanting to change oil for thicker stuff in the diff unit itself, How do you do this. Kev.
phil clegg
posted on 4/9/12 at 07:08 PM |
diff
the lsd part of the diff is not filled with oil,its a sort of super sticky grease,you can change the oil as normal ,if you want to check the lsd you
have to unbolt the rear case flick the shaft flange clips out ,pull drive flanges out and wind out the bearing carriers .then pull out the full diff
and unbolt in half be carefull with the plates keep them in order,all this will disturb your preload so probab best left to someone who has done a
few if not confident....
ReMan
posted on 4/9/12 at 07:10 PM |
Silicone grease/oil I believe. But as far as grade?
www.plusnine.co.uk
mcerd1
posted on 4/9/12 at 10:01 PM |
this man ended up rebuilding the viscous bit by accident: linky
not sure where he got the silicone stuff, but you could ask him
