New Topic New Reply
Author: Subject: MK4 Golf Subframe Captive Nut
SeanStone
posted on 8/10/12 at 08:06 AM Reply With Quote
When replacing the wishbones on my MK4 golf, the front most captive nut for the bolt that goes through the bush has come loose/un tacked
I've been advised that this will require a new subframe, however, is it possible to re-weld this on?
posted on 8/10/12 at 08:15 AM Reply With Quote
If you can get at it you should be able to weld it. You can make a plate with a nut welded to it and weld it in place if you can make a hole for it to go in.
New Topic New Reply
