utuber
posted on 17/5/13 at 10:54 AM |
WEBER 32/36 DGAV 3D3 settings
I have the weber32/36 DGAV 3D3 carb on a 2ltr pinto itis running rich, sooty plugs but there is no fuel/air mixture screw how do you adjust it???
mookaloid
posted on 17/5/13 at 11:13 AM |
Set up guide here http://www.mgexp.com/article/3236dgev.html
Not Anumber
posted on 17/5/13 at 12:26 PM |
If the 32/36 is running the standard auto choke make sure this is not staying on and continuing to enrich the mixture when the engine has warmed
up.
How long has it been running rich for ?
utuber
posted on 17/5/13 at 12:59 PM |
have change choke to manual
Not Anumber
posted on 17/5/13 at 01:30 PM |
Very wise, i should get round to that on my 38/38.
Its quite a rare thing to find a downdraft weber with no idle mixture adjustment. I'm aware of some that had the mixture screw recessed into
the casing with an anti tamper plug. Can you post up any pictures of your carb.
If it doesn't have any external means of adjusting the mixture then the next stop is to check the sizes of jets that are fitted as you can
always drop a setting.
It could be worth gettinbg hold of a colourtune plug, driving the car entirely on the primary throttle and then driving it harder with the secondary
throttle open to see if it runs rich under both conditions. It may be you'd only have to lean up the mixture on the primary side.
utuber
posted on 17/5/13 at 01:34 PM |
new to this forum how do I post photo`s
Not Anumber
posted on 17/5/13 at 01:57 PM |
I tnd to just upload the picture to my webspace and just copy and paste the URL of the image into the post.
Make sure the pic isn't too huge as it will dominate the whole screen
Another way is to upload them to your photo archive here on the forum : http://locostbuilders.co.uk/photos.php . The picture can then be added as a
thumbnail by copying and pasting the [pg ] code on the left of the uploaded image.
utuber
posted on 17/5/13 at 02:27 PM |
Can not seem able to get photo` but it is the same as ebay item number 251276153742
Andy S
posted on 17/5/13 at 07:02 PM |
From here - all you need to know
http://datsun1200.com/modules/mediawiki/?title=DGV
[Edited on 17/5/13 by Andy S]
Not Anumber
posted on 17/5/13 at 07:57 PM |
The mixture screw is there. Its at the base, on the same side of the linkages, in a hole. Hard to see from the outside as you have to use a small
screw driver.
