pekwah1
posted on 19/5/13 at 12:40 PM |
Fixed rate flasher relay
Hi guys,
I bought one of these for my indicators and hazard but although its a fixed rate, it's still too fast.
I have rear bulbs, front bulbs, and side repeater led.
Any idea why my rate would still be too fast?
http://www.amazon.co.uk/gp/aw/d/B0078EFRBS
Regards
sjmatthews
posted on 19/5/13 at 01:40 PM |
Most relays require 21 + 21 + 5w loading to flash at the correct rate.
My buddies Stylus had the same overspeed problem as it only had 21 + 5 + 5 each side, so we fitted a 10 ohm resistor to each side, problem solved.
I'll be in the garage dear!
loggyboy
posted on 19/5/13 at 02:23 PM |
I seem to recall the figure, 60-120 flashes per min, so quite a big variance.
Mistral Motorsport
theduck
posted on 19/5/13 at 07:25 PM |
60 - 120 flash per minute as above is the required standard for IVA.
posted on 19/5/13 at 07:53 PM |
What bulbs are you running? -- ie; type & wattage; front, rear & repeater ?
iank
posted on 19/5/13 at 08:36 PM |
That flasher is designed for LED's and no resistor is required.
What flash rate is it going at? It's specified as 90 per minute +/- 10%
http://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/cf13jl-02-led-bulb-electronic-flasher/783/
Anonymous
