gaz_gaz
posted on 27/1/14 at 08:54 PM |
Motul 300v 15w50
I was wondering if any of you guys had used the Motul 300v oil.
Radical recommend the Fucks Silkolene pro 4 but I can get hold the the Motul for next to nothing.
jeffw
posted on 27/1/14 at 09:02 PM |
I use 300v in the Phoenix....very pleased with it.
How much can you get for next to nothing?
jwhatley
posted on 27/1/14 at 09:16 PM |
I have used both oils.
Prefer the 300V, plus I found the pro 4 went watery after one track day.
The 300v smells a lot better if you have an open breather too. The pro4 has that cat wee smell you get with gearbox oil.
John
daniel mason
gaz, buy it for next to nothing.sell it for a proffit,and run the sikolene! go with powertec
blakep82
posted on 27/1/14 at 09:21 PM |
*snigger*
________________________
gaz_gaz
posted on 27/1/14 at 09:26 PM |
Blake, you big child
Jwhatley, are you still using the Motul oil.
That's not a bad idea Dan
Jeff. How much would you want and I'll make an enquiry?
jeffw
posted on 27/1/14 at 09:31 PM |
See how much you can get....say 10litres ?
bi22le
posted on 27/1/14 at 10:29 PM |
I use fusch ProR. Worked great even when my engine was hitting 120degC oil temp.
I wont change from it untill proven otherwise.
Please read my ring story:
posted on 27/1/14 at 10:48 PM |
*snigger*
Not just me then
adithorp
posted on 27/1/14 at 11:20 PM |
Guy I know who builds a lot of engines for guys doing the IOM TT etc and is ex Virgin Yamaha mechanic, recommends Motul 300v. Says most of the works
teams in BSB + WSB use it despite being sponsored by other oil companies. Doesn't rate the Silkolene
http://jpsc.org.uk/forum/
gaz_gaz
posted on 23/2/14 at 07:13 PM |
[Edited on 23/2/14 by gaz_gaz]
