six mad
| posted on 24/2/14 at 06:49 PM |
CVH EFI Turbo inlet mod??
All,
I need to lower/remove my existing inlet to allow a standard raw bonnet to be fitted. I,m thinking
about creating a new plenum on the lower part of the manifold then remounting the throttle body
towards the front of the engine. I can not lower the engine as it will foul the chassis.
I,m wondering if this will work or if there are other manifolds that could be used/modified?
Obviously i expect some cutting and welding
Thanks in advance
[img]
[/img]
[img]
[/img]
| posted on 24/2/14 at 07:04 PM |
There are compact plenum type manifolds made for the Zetec (e.g. Griffin) and since you can buy an adapter plate to fit a CVH manifold onto a Zetec
head, presumably it's possible to do it the other way around?
pmc_3
| posted on 24/2/14 at 09:13 PM |
I'm putting a RST engine in mine and I was sure i'd seen a photo of one with a modded inlet, i've had a dig through photos
i've saved and found this, which is probably the sort of thing you need.
[Edited on 24/2/14 by pmc_3]
six mad
| posted on 24/2/14 at 09:40 PM |
Yes thanks that's exactly what I was thinking of ,I have also seen a mix
Of the rover plenum used. I have also seen rubber connectors used between the
Plenum and manifold.
What I need now is someone who could fabricate something similar?
I am struggling to find the Griffin inlet?
pmc_3
| posted on 24/2/14 at 09:42 PM |
It looks like in the photo I posted they are using a twin webber inlet manifold with the custom plenum
madteg
| posted on 24/2/14 at 09:43 PM |
Would be easier to make a complete plenum and manifold from scratch as i did, pics in archive.
| posted on 24/2/14 at 10:03 PM |
A Rover M or T series inlet manifold fits on to the CVH head without much modding. Do s web search on it it should turn up info.
I have a Rover 820 turbo manifold in the shed
pmc_3
| posted on 24/2/14 at 10:35 PM |
Could you adapt this?
http://www.ebay.co.uk/itm/ESCORT-RS-TURBO-MFI-RACE-SPEC-INLET-MANIFOLD-WAS-RUNNING-300-BHP-as-in-pic-/281266176232?pt=U
K_CarsParts_Vehicles_CarParts_SM&hash=item417cc540e8
six mad
| posted on 25/2/14 at 12:15 PM |
Yes I saw this myself many thanks, now purchased.
six mad
| posted on 4/5/14 at 07:22 PM |
Thought I would update this thread.
After purchasing the manifold on ebay i found i could not use it how i liked.
So I started to fabricate my own, this is what i ended up with car runs
fine apart from a high tick over which i had with the standard unit.
[img]
[/img]
