SteveRST
posted on 13/8/14 at 08:54 PM |
Can anyone identify this radiator?
Fitted to my '98 Westfield which was CVH powered.
Core dimensions: width 41cm x height 35cm x 5cm depth. Seems to be copper core with brass ends.
It's very heavy - not sure if I'd be better off with a new Polo rad?
[Edited on 13/8/14 by SteveRST]
OliilO
posted on 13/8/14 at 09:08 PM |
Steve,
I've got a new polo rad that you're welcome to for a tenner if you want. I bought it to replace my rad, but didn't end up replumbing
in the end. Probably not worth posting but if you're heading to a SKCC run in the near future I can bring it along.
Mr C
posted on 13/8/14 at 09:15 PM |
Hi Steve, Mike, (b33fy) here, hope all is well, haven't a clue on the rad, though I'm looking for one as well I've been looking at
Radtec's caterham rads bit pricy mind, be interested in what you come up with.
Mike
Girl walks into a bar and asks for a double entendre, so the barman gave her one
Andy S
posted on 13/8/14 at 10:13 PM |
You will be far better off with a polo rad - first mod I made to mine - will save 4kg in weight and provide better cooling.
Mine was an 89 Low Line Narrow body with an 1800 Zetec - rad for a Tenner snap it up.
jollygreengiant
posted on 13/8/14 at 10:38 PM |
Its name is Kevin.
posted on 14/8/14 at 05:57 AM |
The existing rad is custom made basically it is a Ford or Triumph? rad assembled with the top header tank replaced with a bottom tank.
spaximus
posted on 14/8/14 at 07:27 AM |
That is an original westfield radiator they used to supply before they started using the Polo. It was custom made but is fully repairable at any
radiator repair shop. They are made of copper and brass so a bit heavy but very robust.
A polo rad is a good swap if saving weight is what you want. No point going to a radtec with just a CVH as the polo rad is will cool a VX 16v no
problems.
Mr C
posted on 14/8/14 at 09:32 AM |
problems.
Its been modified a touch since the cvh..
I'm looking for a rad suitable for a supercharged duratec I can go a little wider than the standard caterham polo rad up to 500-530mm now
thinking Honda Civic Rad..
SteveRST
posted on 15/8/14 at 10:46 PM |
Thanks for your replies guys. I had not been able to find one on google, so as you say, it must have been a custom job.
Yeah, car is now running 2.0 zetec with a turbo but I've only noticed temperature creaping up during some prolonged thrashing or after 15 mins
on track.
Don't really want to swap the rad out as that means re-routing cooling, fan, charge-cooler rad. At the moment I'm modding the nosecone for
more airflow and boxing in the rad so that air that enters the nose has to flow through the rads.
steve
Andybarbet
posted on 16/8/14 at 07:31 AM |
It may be worth taking it somewhere to get it re-cored, years ago I had my mini one done & they double cored it which made it cool much better,
could be worth seeing if its possible with this one.
Atleast you can just refit then with no mods to the mounts etc.
