New Topic New Reply
Author: Subject: pc3 ignition problem questions
jlayton
posted on 4/7/15 at 06:51 PM Reply With Quote
Hi as above with a pc3 usb do you need the ignition module and multi hub with boost input harness and sensor, To run a bec turbo safely. As I have bought both but just read the boost input on the multi hub can adjust the ignition timing
New Topic New Reply
