mutleylocost
posted on 22/2/16 at 09:25 PM |
locost half doors on eBay auction for £80
Stuck a pair of fiberglass half doors on eBay at £80
Need a guinea pig to buy a set, fit them, and post some pictures on here
z2000
posted on 23/2/16 at 07:12 AM |
It may be a silly question....but do I take it the curve for the rear arch on these half doors must be more or less the same as any other kit?
The reason I ask is I have a GBS Zero and although it's a full cage, the cage shouldn't interfere with the half door but I just want to
understand if the curve will match up. Length and height should be fine but I'll go measure soon.
Thanks,
Henry
If it isn't broken; take it apart and fix it! Build PhotoBlog:
http://z2000.co.uk
mutleylocost
posted on 23/2/16 at 07:37 AM |
It's the same curve / radius as the Locost / Haynes book chassis. It must be the same on most 7 type cars. My car has caterham rear arches and
the door follows them on a very similar radius. Check out the photos on the eBay listing as that gives you an idea and I will measure the radius when
I get home and stick it on here
z2000
posted on 23/2/16 at 09:15 AM |
Great, thanks very much.
Sure like you say they're all more or less the same radius.
http://z2000.co.uk
mutleylocost
posted on 23/2/16 at 08:20 PM |
The curve on the end of the door sits very nicely on the circumference of a 26" push bike tyre
The diameter of the tyre is 660mm or 26"
Hope that helps
alfas
posted on 23/2/16 at 09:56 PM |
isnt the cockpit on a GBS much longer than on a Locost?
mutleylocost
posted on 23/2/16 at 10:00 PM |
The doors measure 950 mm long and are 190 mm tall
