moosdad
posted on 15/11/16 at 11:15 AM |
BEC launch control?
Does anyone know of a launch control system that will work with a bike engine?
I have a 96/97 fireblade (919) and think this would be an amazing mod!
I have seen the Omex system for cars, but unfortunately its not compatible with CD ignition, which i believe the blade engine runs.
Any help or point in the right direction would be brilliant.
Dave
daniel mason
posted on 15/11/16 at 06:14 PM |
Think xoomspeed do one
twybrow
posted on 15/11/16 at 07:35 PM |
I would ask why? It will put strain on an already strained gearbox. I avoid standing starts for this reason, but if you are less mechanically
sympathetic than me, then go for it! Most OEM systems limit the revs as a function of wheel speed and gear choice, allowing just a little over
rotation compared to the forward speed. So to emulate this, you could need an array of sensors front and rear, a rev limiter and an ecu to control
it all... Good luck!
LBMEFM
posted on 15/11/16 at 09:39 PM |
I also try to avoid fast starts with my bec as the car is heavier on the gear box than the bike as stated above, also the clutch will not withstand
the extra loads for long. I would recommend that you don't fit it.
daniel mason
posted on 15/11/16 at 09:54 PM |
We launch the hell out of them on fat super soft slicks up to 10 times per event.
james h
posted on 15/11/16 at 10:03 PM |
If you do fluff a launch, make sure it's because you lit up your tyres. I had a passenger in mine when I did a hard launch, but it bogged down
massively (more traction over the rear wheels), and overheated the clutch, so the plates fused together! Managed to unstick them, but it was a good
hour in a car park sorting it out.
mark chandler
posted on 15/11/16 at 10:19 PM |
Mine gets hammered, lock up clutch, turbo and the gearbox only blew because of a botched change down, 4th to third at Blyton, I really would not worry
about it.
Changing the gearbox is only a few hours anyway once the lumps on the table.
moosdad
posted on 16/11/16 at 12:32 AM |
Thanks everyone, it wouldn't be an everytime thing just an occasional ultimate standing start!
But let's face it, in my case, I can pick up an engine for 400 quid, and 2 hours or so to fit!
I only got the car earlier in the year, and am finding it really difficult to launch it properly.
I've spent time weighting up the clutch and accelerator to get them more car like, but I'm still having trouble.
And the icing on the cake is a mate of mine is about to buy an exige.. So hence the launch control idea!
I'll email about the xoom one, but ultimately it's pretty much a no go if they are 6 - 7 - 800 quid
Dave
Matt21
posted on 24/11/16 at 11:42 AM |
If you're struggling to launch it there is something amiss either with the car or your driving
The only time I struggle is with two people and hot tyres (R888), too much weight and grip on the back end and not enough grunt.
full throttle, as it gets over 10k just dump the clutch and off you go. Slight adjustments on the throttle by just feeling how the car is reacting.
Too much spinning then back off very slightly, bogging down, add some throttle.
There's no right or wrong you just kinda have to feel whats making the car accelerate quicker and whats hindering it. But this changes every
time you do it depending on the road surface (not public roads, obviously) temp, tyres, tyre pressure, tyre temps, weight in the car, geometery etc
etc
Works a lot better with just one person in so practice that first. I'd suggest avoiding it with 2 people on a summers day...
Instagram: @matt211988
Photobucket
My YouTube
