max2503
| posted on 12/8/17 at 09:02 PM |
Bike Tachometer
Has anyone fitted a motorcycle tachometer in their project? I just like the look of some of them, and it would be something different.
I'm running a 4age with an emerald ecu.
Many thanks
Nathsx
| posted on 12/8/17 at 10:39 PM |
Its been done plenty with the bike engines unsure on using it on car engine though
| posted on 13/8/17 at 11:15 AM |
The majority of 4 cylinder bike tachometers would only get a fraction of the range used when hooked up to a car engine.
Angel Acevedo
| posted on 14/8/17 at 06:36 PM |
It will depend on your Redline and the redline of the Donor motor on the Bike.
If you don´t mind it is irrelevant as long as the donor bike tach rerads higher than your engine can rev....
Which leads to what Mike RJ is talking about.
Nathsx
| posted on 15/8/17 at 10:19 AM |
https://www.carbuildersolutions.com/uk/all-in-one-digital-dash-10k-
black-face
This gives a similar idea but much less RPM, Fairly costly though
