New Topic New Reply
Author: Subject: Volt meter, Temp meter and USB to a vintage car
theprisioner
posted on 22/3/19 at 08:00 PM Reply With Quote
I thought I would share this little discovery with you
3 in one cigar lighter device
The idea is to conceal as much as possible the volt meter, temperature gauge and USB outlet on the dashboard.
Austin sevens never had temperature gauges, some say you don't need them but what happens if the engine puts out 3x the original power? I have thermostatically controlled the coolant and I need to keep an eye on the temperature.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Angel Acevedo
posted on 23/3/19 at 01:32 AM Reply With Quote
I was going to go with USB/Volt indicator, but thought it was too modern looking.
I went for two separate units, USB double port and Cigarrete Lighter port.
This
USB/Cigarrete Ports
Water Temp and Volts are shown on VDO Analog Gauges.
New Topic New Reply
