Johnm
posted on 15/2/05 at 02:47 PM |
Westfield High Effeciency Radiator
Just been looking at the Westfield online shop and they have a high effeciency radiator, which looks to have the inlet and outlet connections at the
top (ie no bottom connection).
My question is, does anyone know if you can run a polo/golf radiator in the same configeration, this would allow me to also install the oil cooler
next to it in the nose cone. As the oil cooler is over 500mm long this would also be mounted vertically, with the feed and discharge nozzles at the
top.
John
Johnm
posted on 29/3/05 at 09:28 AM |
Didn't get any replies, so progressed anyway - purchased a Polo Radiator, which measured about 530 x 322. This mounted so the inlet and outlet
ports were at the top of the radiator. Water is forced; because of an internal division plate to flow down one half of the radiator from the inlet
port and then up the second half to the outlet.
Took the car for a long run over the weekend and the car runs cooler than it did with a two row Cortina rad and if parked and run for a prolonged
period at idle, when the rad fan does come on it does so for very sort bursts, unlike with the cortina rad, which ran most the time when it
started.
An added advantage of the current set-up whcich is off-set to one side of the nose cone is the air filter has room to sit in the nose cone also so it
always draws air from the cold side of the radiator.
All gaps around the radiator were filled so all air has to go through radiator and cannot by-pass it.
For info the cooling system is cooling an RX7 engine with 170 bhp at the wheels
Regards
John
billy
posted on 19/4/05 at 08:45 PM |
Hi johnm, sorry that your post went unanswered this is 1 section i dont visit much, your car sounds cool, put some pics of it in your pic archive
so we can all see her
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
barraw
posted on 21/4/05 at 10:46 PM |
I recently had my mk1 escort radiatior remanufactured by Serck Marston - and they did a great job - it looks brand new. However, that combined with
my oil cooler is actually over-cooling the engine - ie it can't get up to normal operating temperature, causing lots of condensation and water
in the oil. Careful not to over-do the high efficiency cooling.
NS Dev
posted on 13/6/05 at 03:20 PM |
if the thermostat is working you can't overcool
