bikkel
posted on 26/1/06 at 08:08 PM |
electric waterpump
hi all
i'm about to fit a drysump to my zx12,
and the mechanical waterpump is needed to fit the oilpump.
so an electric waterpump is necessary. craig davies or equivalent
should i use a controller?? what brand ? craig davies?
or run it continious.
use : road /trackdays
thanks koen
www.zx12r-indy.tk
RazMan
posted on 26/1/06 at 10:17 PM |
Unless you are racing I would say definitely use the CD Controller unless you can hack into your ECU for the control.
Also make sure you get the Mk3 pump which apparently has better bearings.
Raz
